Ebike Charging; Fast or Slow?
December 20, 2015
Everyone likes a fast charge…the idea of charging your battery pack quickly is an exciting concept and its actually very possible. However, as it is with all of ebiking…high performance comes with significant drawbacks.
So you might think that the higher cost of a faster charger is the only consideration when upgrading chargers, but…it’s not! You will notice that there are not many ebike chargers available on the market that charge at more than 5-amps…and that is because of the dangers of charging an ebike battery too fast. For the purpose of this article we will consider 5-amps as fast charging, and 3 amps or lower to be slow charging.
Pictured below is a standard 5A charger that most ebikers have become acquainted with. Its made from aluminum and not plastic because the aluminum acts like a heat sink to help keep it cool.
ebike charger
________________________________________
Woah, Lets Slow Down!
We know that everyone appreciates a fast charge…the idea of charging an ebike battery in an hour is an exciting concept. Once you get into the ebike math, the first notion is to get as high an amp charger as possible. With a 10-amp charger you can charge a 10-amp battery in one hour…lets buy one! right?
But charging too fast is hard on the battery, and it will cause its life expectancy to go down, and also it can be a fire hazard in extreme cases of charging too fast.
We really recommend that if you are new to ebikes, and new to lithium batteries in general, that you stick with the slow charger that came with your pack, and do not fast charge. This is both safer and healthier for your pack.
Ebike Charger Math
One of the questions you should ask when buying an ebike is how large is the battery in Amp-hours (Ah) and how many amps is the charger it comes with? Then using ebike math you can quickly calculate how long your battery will take to charge. We know based on ebike math that charging a 10-Ah battery will take 10 hours with a 1-amp charger…or 2 hours with a 5-amp charger.
If  you divide the amp-hour rating of your battery by the amp rating of your charger, that is how long it will take you to fully charge your battery (if it is fully discharged). However all good lithium smart chargers dial back the charge at the end of the charge cycle, so they take a little longer than what they are rated for. So, for a 10 amp hour battery, it will take a 5-amp charger a little more than 2 hours to charge your pack.
Here is a drawing which illustrates how a typical ebike charge cycle works. As you see the amperage of the charge starts to dip once the battery reaches 80 percent charge. This is so it will be as gentle on the battery pack as possible.
manual2
A high-amp charger will only actually use high-amps until the battery reaches about 90% of its full maximum possible charge…then it will use low amps to gently “top off” the pack.
_________________________________________
BMS Limits and charging fast:
Commercially sold ebike batteries such as the Luna Cycle packs have some kind of BMS (battery management system)  that protects the pack. One of the things the BMS does is limits how fast the pack is allowed to charge. If you plug a 10-Ah battery into a 5-amp charger, and the battery does not charge, the BMS might be refusing the charge.
Most lithium BMS’s have a limit of around 7 amps as the limit on how fast they will charge. Also, the BMS is in charge of balance charging your cells to further ensure you packs safety and longevity.
__________________________________________
The Importance of Balance charging
Any good BMS not only protects the safety of your pack during charging and discharging it also ensures each series of cells is balance charged, which means all your cells are at about the same voltage.  Balance charging does not happen fast…in general most ebike  chargers will slow way down at the end of the charge to allow a proper ebike battery with advanced BMS to balance out each line of cells.
Chargers that Charge Fast AND they can charge Slow
ChargerLunagizer
For an advanced ebike charger that can charge both fast or slow, you have two choices as of this writing. The $300 Cycle Satiator that was previously mentioned, or the $100 Luna Advanced Charger which will charge at either 3 amps or 5 amps. Both chargers are very good. The Satiator is more advanced and the Luna Charger is more affordable.
A third good option is if you already have (and know how to use it) is an RC charger with an external power supply. The RC charger must be able to match the voltage of your pack, which is rare in an RC charger to get up to 48 or 52 volt battery, but they can be found. These chargers can be a wiring  mess and their Chinese interface makes them very difficult to operate.
The Size of your Pack Really Does Matter
The larger the battery, the safer and healthier it is to charge at high amps. For example, 5 amps is fast for a 10 amp-hour battery, but not so fast for a 20 amp-hour battery.
When you charge your battery fast all the time, it will greatly reduce your batteries life expectancy. We recommend you stick to slow charging (4 hours or more) or go with a charger that can switch between fast and slow charges like the Luna Charger.
Now if you have a 10-Ah battery and you have a 5-amp charger…that is a super fast charger for that pack.
High Quality Packs Can be Charged faster
If you have a pack consisting of high amperage cells like the Samsung 25R cell, and your pack is capable of high discharge, but…it will also accept fast charging without degrading your packs life expectancy too much.  The drawback to these cells is they are expensive and they are not as energy dense as some lower performance high capacity cells such as the Panasonic NCR B (3400-mAh, instead of 2500-mAh for the 25R). So how can you tell if you are charging your pack to fast?
The Finger Test
The quickest way to tell if you are charging to fast is to put your finger on your battery pack when it’s charging and see it the pack is getting more than a little warm.
If it gets fairly warm, you are degregating the life of your cells and its time to invest in a slow charger.
Buying Advice
First of all buy the largest battery that you can carry on your bike, made with quality cells. Here are some good options when choosing what amperage of charger to buy:
#1  Buy a fast charger AND a slow charger.
Until recently this is how I did it…I would have a 5-amp and 2-amp charger around for every voltage of battery I owned.  I had a box of chargers..i solved this by investing in one advanced charger.
#2 Just buy a slow charger, and forget fast charging.
This is the safest way to go, the cheapest way to go, and the way that will make your battery last the longest.
#3  Buy a big ebike battery (20-Ah or more) and charge it at 5-amps
A big battery solves a lot..they are less delicate and can handle a fast charge. Also with a large enough battery you won’t have to worry about charging in the middle of the ride.
#4  Buy a fast charger and just let it rock!
Who cares if you lose a couple hundred cycles in battery life?…you will still get hundreds of rides and that will probably be able to survive years and by then you will want to replace your battery pack anyway with something better and lighter. This is what a lot of hot-rodders do, they buy a new battery pack every spring and beat it to death until it’s cold at the beginning of winter. Next year? they use the old battery as a back-up…
But now just in 2015 there is another option:
#5 Buy an Advanced Variable Amperage Charger
Rather than buy two chargers, the ideal alternative is buy one charger that can either slow charge or fast charge with the flick of a switch. The  $100 Luna Charger and the $300 Cycle Satiator.  Both these chargers can be set for either a fast or a low setting so that you don’t have to have multiple chargers around and thus reduce the wiring clutter that ebikes tend to make (read our story about the ebike  ratsnest)
Home Made Ebike Packs Charging Insanely Fast on the cheap
Here is an example of  well-made home built pack (they usually look a lot worse). All the little white plugs you see coming out are balance plugs (which is a good thing that many garage builders leave out!) .
Some very knowledgeable ebike builders attempt to use RC LiPo packs that are not BMS-protected to save money.  Also, since these packs are not output-limited with a BMS, they can not only put out a lot of amperage discharge, they can also charge very fast. But, charging fast is hard on the pack and can be dangerous.
Generally they use power supplies as a charger, by using units made by companies such as Meanwell that match the voltage of their pack (they can be stacked in series to reach any voltage you want, like 100V! Don’t try this at home, leave the modifications to professionals). You can buy Meanwell chargers in all sizes, some that can even charge at 60-amps!
Also when you charge this fast without a BMS, the cells are not being balance charged which will drastically reduce the life of your pack…and you will have to rig an apparatus for balancing separately if you want to charge safely. Obviously this can become somewhat of a wiring nightmare. (read our article on the ebike wire ratnest)
We really recommend that you go with a professionally-built 18650 pack or you really do serious research on endless-sphere.com before undertaking building your own pack.
Written by Eric, December 2015
12 Comments
  1. What about fast charging to 80%…like the Tesla and others do…less degradation of battery.
    Can you get a charger that cuts off at 80%?
    Or how would you measure (easily) the battery was at 80% AND the cells balanced?
    If 80% charging is possible i would get a slightly bigger battery pack…and fast charge.
    • Grin technologyies in Vancouver BC.I bought their 48 volt battery with the sator charger. Cuts out at 80%.Nice as your not still charging and turns off,The front panel light is lite and the sator bracket is cold. Battery is charged.
      Rusty
      • Cheers…
    • Yes, both the settings on the charger and battery PCM are able to get a charger cut off around 80% capacity,but usually at a higher level for longer range.
      The battery capacity can be generally measured by the voltage, the cells balanced by the PCM automaticly, and inspected by the cell voltage.
      Actually, fast charge e-bike can be available in North American already, you can try to find a desirable powerful e-vox from Procycle in Quebec, or their authorited dealers around NA.
  2. i still don’t understand with the ebike market as big as it is how companies like bosch aren’t simply buying out grin cycles technology. everyone is worrying about ecars, but there are hundreds of millions of ebikes in the world and many people want them, the big obstacle is charging speed, and the problem IS NOT the wall outlets , because almost all countries have outlets capable of at MINIMUM an 800 watt power SAFELY out of the outlet . ebike batteries of 400 watt hours should be able to charge in twenty minutes to 70%+ without any difficulty ———-and even with the satiator, they are not yet near this speed.
    this is room for improvement, with teh chargers and with the cells.
  3. I have to disagree in this statement “charging a 10-Ah battery will take 10 hours with a 1-amp charger.”
    Any properly programmed BMS will leave a minimum 20% capacity at LV cut-off, so it would be more like a “10Ah pack will take 8 hours to charge at 1 amp” because you already have 20% capacity remaining. Otherwise you will kill the cells if you run them down to near zero.
    • As stated above by Eric that, “However all good lithium smart chargers dial back the charge at the end of the charge cycle, so they take a little longer than what they are rated for. So, for a 10 amp hour battery, it will take a 5-amp charger a little more than 2 hours to charge your pack.”, the charging time is usually 1.5times than this theoretical value, that is, it takes 3 hours for the 5A charger to charge the 10Ah battery pack fully.
      You don’t need to worry about the over discharge, since both the e-bike system and battery PCM will work for that, warn you of battery low power, and then cut off automatically.
  4. Actually slow charging is worse than “fast”. And by fast you should say 1C. So 10A for 10Ah pack. This would be too much. But for any modern 18650 cell recommended charge rate is 0.5C = 5amp charger for 10ah pack.
    Situation changes when battery starts to show signs of wear and capacity drops. So i would recommend getting charger close to 0.5c but below.
    You can learn more about benefits of ” fast charging” by studying documents about lithium batteries and why do they die out. Most common problem is constant reaction in cell. Cell should be charged and dischagred quite fast to limit time of reactions. There’s a video on youtube “why do lion batteried die out”
    • Yes, you are right, the standard charging rate is not over 0.5C. 🙂
  5. So I realize that charging my 8.7Ah battery pack can’t be done in half an hour (not even close). I am doing a project for my studies so I will have to clearly explain why I should go for the option to change the battery pack when it is empty, to be able to provide my electric scooter a fully charged battery within half an hour. How can I clearly explain that it is not possible to charge a battery this fast?
  6. One thing that seems to be missed by many people is that the Cycle Satiator is used primarily (at least by me) to extend the life of the battery. Not abuse it like a cheap date. After any ride that I end up at a friendly 120v outlet for the night, I will slow charge up to my standard 80% charge. Then wake up in the morning and have a standard daily charge to use – 80%. So yes, buy the largest battery your bike can carry safely because you don’t even get to use the 80%. Wait what!?! You are only going to charge to 80% to help extend the life of the battery right? Well then your also not going to discharge past 20%. That leaves 60% of your batteries capacity to spend in any way you want, and doing it in a manner that will extend the number of recharge cycles dramatically. Psssst! Big batteries ain’t cheap, unfortunately not light either. Come On Technology!!! Every One Follow Me! “Lithium, Oxygen”, “Lithium, Oxygen”, “Lithium, Oxygen”…. Doesn’t really roll off the tongue does it? Well from everything I can read it sounds light and that’s almost as important as performance is, ask NASA. It will all balance out, they will be light but also so expensive it will make you puke. So how do you use that 60% of your batteries capacity best? Depends what you want to do with it. Faster you go the less distance you can travel. The slower, the further you can go. Is distance important to someone riding a BMX track and trying to see how much dirt they can make the buddy eat? Nah. Is speed important to a long distance tour rider? Maybe so, but ya can’t have it all. Not yet anyway. What you can do if you use your 60% in a foolish 25 mph, 10,000-foot accent is Fast Charge the battery at any outlet you can find for a couple hours and then finish up with an all-night slow charge at another friendly 120v outlet. The bigger the battery the less chance you will do much damage in the occasional fast charge. But just like coasting along for 15 miles without peddling, it’s not a good habit to get into if distance matters. The Cycle Satiator allows you to treat your battery with respect or like a hot tramp, whichever is most called for at the time. Where is Elon Musk when ya need him? Let’s slow things down and do them right, ok Gizmo? Let get a battery pack that can be used in 1 to 5 hp electric motors and up. Then use this pack as the standard for everything, bikes to lawn mowers to home battery storage systems to large vehicles. One “Pack” to lead the All! Elon. Well, at least until the next evolutionary leap in battery technology, what, Carbon Fiber Aero-Gel Capacitance? I can’t wait that long to ride where I want! But Sure! Stumble off to some other poorly conceived world changing idea that you will never see come to fruition. Or worse watch the Chinese grab it and have a thousand-mile hyper-loop up and running in a year or two because they have the money and comment to do it right. Give me a battery that I can Slam-Charge to 80% in the time it takes to get some maps and suggestions from my friendly forest ranger.
  7. It would be helpful if you defined the cutoff voltage for 80% and 90%.
    Would that be 80% of the max charge voltage: 0.80 x 4.2 Volts/per cell
    or
    would that be 80% of the charge voltage differential : (0.80 x (4.2 -3.6)) +3.6 volts base Volts/per cell
    Never assume that the consumer/end user can read your mind.
%d bloggers like this:
