Regenerative Brakes on Ebikes
April 20, 2013
Regenerative braking is very common on electric cars, and rare on electric bikes. Regen means that the electric motor is used to slow you down when stopping and generating electricity which is fed  back into the battery pack which increases your efficiency and increases range. That is how a Prius is able to get almost as good of gas mileage in stop and go traffic around town as it does on the highway.  Obviously, the regen braking system offered on electric bikes is much less sophisticated than the ones offered on electric cars. Ebike regen is usually just on or off and has mild stopping power and is used in addition to manual brakes. Usually on an ebike regen happens when you softly apply pressure on the brake handle and you feel the regen brake kick in….compress the brake handle more and the regular brake activates. Variable regen for an ebike where you have variable amounts of regen based on how hard you hit the brake handle does not exist as of this writing.
Regenerative Braking and Efficiency
The efficiency gain of your regen system will largely be dependent on how hilly your riding environment is, and the style in which you ride.  Basically:  how often do you stop-and-go and how hard do you stop? Regen can add anywhere from 5-20% efficiency but average rider on the average terrain will get  about 10% further distance per battery charge.
What about drag?
Regenerative brakes on an ebike create a bit of extra drag, even when not using the brake. This is because the motor is always engaged in an ebike with  a regen system, so the motor is always turning even when coasting.  This drag is so small its imperceptible when riding. However it does cut down a small bit on the efficiency of the bike.  However, the positive effect on efficiency of a regen system, greatly outweighs the small negative effect created by this drag.
Regenerative Braking and Brake Wear
Regenerative braking can drastically reduce your brake wear and also keep your brakes from getting to hot on extended down hills. Also regen never squeaks and has a nice smooth feel to it. Its a nice and  liberating  feeling to be charging your battery while riding, rather than creating friction and heat with traditional brakes.
Which bikes are capable of adding Regen?
The easiest motor set up to add regen too would be a gearless hub motor. Geared hub motors have freewheels and therefore cannot have regen. Mid drives could possibly have regen but its harder to implement.
How easy is for a manufacturer to provide regenerative brakes?
classic cruiser
None of the Pedego gearless hub powered bikes have regen…what a shame
On a gearless hub motor very easy. Its suprising that manufactures such as Pedego that sale their best selling bikes with direct drive hub motors have not implemented regen.  You would think it is expensive and complicated but it is not. It would literally costs these companies less than $10 to implement it, by just changing to a slightly more expensive controller.
How is Regenerative braking implemented?
It is a simple circuit inside an ebike controller. Since the controller on a production bike already has wiring going to the ebrake (all production electric bikes must have an ebrake cut off), it requires no additional outside wires.
Which production electric bikes have regen braking?
With most modern production bikes choosing small geared motors, regen on a production bikes has been  rare. The big exception to this is any Bionx powered production ebikes (Ohm, Smart, Grace, Trek, etc)
Although it is very easy for any electric bike with a gearless hub motor to have regen braking, only a few companies have implemented it. However most of the high end bikes with direct drive hub motors have implemented it such as:
stromer st1
The Stromer St1 has regen brakes and Magura Hydraulic Brakes…sweetness
smart4
The Smart bike with its Bionx motor has regen
specialized-turbo
Speciailized Turbo has Regen
bomber_red
The Stealth Bomber has Regen
grace1
Grace electric bikes have Regen
ohm-xs700-08
Ohm bikes have Regen
What if i want to build my own electric bike with Regen?
controller
It is easy. Just be sure you buy a direct drive hub motor such as the Crystallyte or 9c hub motor, and make sure the controller you buy has regen ability. The easiest way to build a bike with regen is invest in the Bionx kit (read review) which comes stock with regen.
 What about variable Regen?
20130308-IMG_2732
Variable regen is a real sweet spot for an electric bike and is not available yet. Ebike regen is usually a  simple on or off.
The one exception to this is the Bionx kit which you can control the amount of variable regen on the dashboard if going down an extended hill.  In the above photo you can see four bars of pedal assist, and if you hit the minus key on the dashboard, you can get 4 levels of regen. Pretty sweet.  Bionx seems one step away from adding this to the brake lever where you can get different levels of regen depending on how hard you apply the brake.  Kudos to Bionx for having the best regen system available for electric bikes.
Here is a video of how the Bionx variable regen works:
 Technical testing information about Regenerative Braking
Justin Lemire Elmore, one of the worlds leading ebike engineers, did a great technical test piece on regenerative braking.   You can read his findings regarding regen on this thread on endless-sphere.
justin lemire elmore
23 Comments
  1. Thanks for the explanation of regen braking. I’m not a big fan of regenerative brakes on bikes. They work well on cars due to the weight of the car and the amount of braking most car drivers do. Bicyclists don’t have the weight factor, plus they do far less braking for numerous reasons.
    The added drag factor, no matter how small, makes the benefits of bicycle regen braking a wash, at best.
    As always, your blog-post was awesome, but I’m not a regenerative braking convert.
    • That’s ok 🙂 not everyone has to believe. Take a look at this link and read through the thread if you have a chance: http://endless-sphere.com/forums/viewtopic.php?f=2&t=7891
      • i m using magic pie2 front hub motor . Regen braking good when braking softly you can brake without using brake pads either on flats or going down long steep hills . as generator this type of motor on battery plugs gives approximately as much Volts as your speed (rim is 700C) .On 48 V system may be not significant difference on distance per charge . but on 36 or 24 it may could a bit charge battery when going downhills .
  2. Pete,
    All of our research and development support the opinion that regeneration is not effective on an electric bike. We believe that the amount of energy captured by even the best of systems is irrelevant to extending range. Claims of it by manufacturers is purely hype and I would question the integrity of those that make the claim.
    • Don (owner of pedego) thank you for checking in. Regenerative braking is not hype…it is used on other high end electric bikes which use direct drive hub motors such as the Stromer St1, all bionx bikes and the Specialized Turbo. I really encourage you to read the testings and findings done by Justin in this thread http://endless-sphere.com/forums/viewtopic.php?f=2&t=7891. Interestingly in that thread he says that the negative stigma of regen was created by the manufacturers who do not offer regen. I am not saying this is you at all…but i think regen would be a great addition to your Interceptor and Comfort Cruiser lines. Seriously read that post and consider it. And please dont call me “Pete”. 😉
      ERIC
    • It’s not hype but rather a mathematical certainty. The kinetic energy you (or the battery) expend to get up the hill gets converted to potential energy at the top of each hill that can can be harnessed going back down the hill. The only thing that comes into question is the efficiency of each component used to harness the potential energy. Hilly terrain offers the greatest efficiencies, assuming you make it to the top.
    • I tend to agree with Arizona. With a high speed car or motorcycle using large batteries more able to absorb high amperage from regen it makes far more sense than what smaller e-bike cells are able to handle without overheating. Heat is the battery cell killer…especially cells that don’t have proper cooling jacket and heat (or cool) unevenly. Using lithium is technically more challenging than lead acid also, due to the need for sophisticated BMS that’s also got to prevent shorts.
      Put another way, 12Ah lead acid battery shouldn’t be charged with more than 3A unless you’re
  3. Thanks but no thanks I will take my freewheeling geared hub over regen any day. I bet the amount of battery charge saved by being able to coast freely is greater than regen to the battery for total range of the battery. Also here is another opinion on regen.
    http://www.ecospeed.com/regenbraking.pdf
    • I reread both articles both talk about 10% regen. I would like to have seen a graph line show the charge level of the battery before and after regen. If 10% regen only equates into .7 miles extra miles it sounda more like tech overkill and a sales gimmick to justify the high price on some of these bikes that use it. I have seen Justin’s videos before about motors and water. Long video, but low on useful information other than don’t let your motor get wet. Face it we are not reinventing the electric motor here. Electric motors have been around for a long time. Most of this has already been figured out. Also what is telling is Justin’s bike ODK 2 that he designed has no regen because it uses a geared hub.
    • That article assumes you are riding in Saskatchewan. If I use the 75 stops x ~15 seconds/stop, that equates to about 20 minutes of equivalent downhill braking while draining the battery going uphill. Regenerative braking will provide significant gains on undulating terrain, particularly if slighter grades are manually pedalled uphill.
  4. Falco offers 5 levels of assist and 5 levels of regen, variable regen on braking, and regen that kicks in to keep speed from topping 20 mph on U.S. models. By pedaling down hills at 20 mph or more in rolling terrain, I do see the voltage drop staved off and the range extended on my Trek 7300 with a Falco 500 watt motor, running a 36 volt,
    11.6 ah battery.
  5. I really only care about smoothing out the hills – to have a system that will save my brakes on the downhill and get me up the next hill. I don’t care about riding faster or plugging in to ride with less effort. Has anyone optimized a system to do this?
  6. To the folks who take the position that Regen is useless or miniscule on an electric bike I say, Get your facts or get some experience. I am looking for a replacement for my BIONX PL350 which has rolled the odometer over two times (>13,000 miles). The batteries are still going strong with over 500 charge cycles and range more than 30 miles with me pedaling and the thumb throttle full bore at 20mph. The only reason I need to replace it is the Hub aluminum case broke out the center where the freewheel screws on. If you ride hard and need to slow down the way I do then you will need aggresive braking which the PL350 has. Four levels of regen braking to be precise. I test rode a Stromer and be aware that there in no regen braking on the Stromer while the battery State of Charge (SOC) is above 50% what’s with that? The Stromer designers have not figured out how to regulate DC Buss voltage. I would have bought a Stromer if I had not discovered that on a test ride. Sadly none of the E-Bike manufacturers have been able to do this. Yeah right, if you listen to tha “Also Rans” they pooh pooh the idea. Too bad they don’t waste the few bucks it would cost them to implement regen. On a brushless synchronous motor the hardware required is minimal. I think the detractors are just not smart enough to manage the technical part of implementing Q4 motor operation.
    Regen makes a difference. Get over it folks. Electric cars would never be without it. Someone said “What about the Huge Amps that might kill your battery while regening?” Come on people I suppose those Huge amps are insignificant out one side of your mouth and mega destructive out the other side of your mouth.
    Too bad BionX is the only one out there that can do this. I keep looking.
    Someone please educate me about why it is preferable to turn up your nose to this technology and shun Regen braking.
    Or Else if you see any other companies finally getting it together let me know who they are.
    Cheers, Rich
  7. The vast majority of electric bikes with direct drive hubs actually have regen. You just have to be going faster than the motor can go at the current battery voltage. The freewheel diodes in the mosfets rectify the power to DC back into the battery but you usually won’t notice it unless you are going really fast down a hill and have a voltage readout.
  8. I bought my first E-bike in 2007 and it was PAT, it had 5 modes of pedal assist 750 wat motor and also had regen brakes. I have nothing bad to say about the regen because i NEVER noticed it lol, but it has been around for long time now. At least 8 years. It’s nothing new but for a bicycle like others stated its not enough to notice or even care about. With the 90 + volt batteries and over 100+ mile range i find it hard to believe anyone is gonna notice or care about saving 1 mile on regen if that.
  9. I have a Motorino XPn with Regenerative braking that I purchased recently. If I applied the brakes a little to activate the regenerative braking, will the Brake lights come on? I don’t want to annoy drivers behind me everytime I touch the brake handle.. I have ABS brakes and it seems a bit sensitive when I apply the brakes ever so slightly. I don’t know if it’s the system or the brakes needing to be bled or something.. Advice would be great.
  10. On most hills the rider reaches terminal velocity at about 20 to 30 mph due to wind resistance. To regain some useful battery storage out of potential energy due to gravity the rider would need to be going slowly to avoid turning this energy store into low entropy (dispersed)wind movement. They could add 100W to this by pedaling down hill which would add up to something useful if the resulting 4A or so was at an acceptable charge rare, which I guess it would be…enough power might be saved to climb another 150m vertically, or thereabouts. On the other hand I quite like freewheeling down hills at 30, not pedaling down them at 10mph…
  11. I have incorporated a regen circuit into my custom bike….I used a rectifier connected to the batteries on the out-put and the hub motor as input….the rectifier stabalizes the input current from the hub motor to whatever current I wanna charge my batteries….so if the hub motor is giving 10 v or 15v I use a step up rectifier to keep the output to battery at 54.6v….I use a double pole double throw toggle switch….this switch to turns on the regen circuit and switch around the connection points on the rectifier to battery(took a while to figure out connecting the toggle switch but I did it)…..I use it mostly on the trail or in my community…..I will incorporate it in my brakes when I get the time. It really slows down the bike a great deal going in a stop and puts on a little topping on battery packs….also the regeneration even though switched on does not kick in until the bike moves 7.8 m/h so pedalling slowly on the trail is a great plus and regen automatically kicks in as the speed goes over 7.8m/h. Also the rectifier allows the bike to be charged with a regular 12v charger at a pretty decent rate…..so 2 twelve volt chargers connected in parallel at 6 amps each that’s 144 watts per second…..so its cheap…….inverter cost about $12 charger about $12 a peice.
    • could I ask you elaborate on your system I am trying to figure out how to add this to my existing skateboard controller
  12. Somehow your article was at the top of microsoft bing search results. The only valid information you provided was which models offer regen capabilities.
    I’m trying to make a million dollars. I invented, and explain, regenerative ebike on my website. You can’t say that motor gear friction is a brake because the only parts that are brake parts are named brake parts. If someone says, “go pick up the brake parts” and you hold an alternator and say “here it is”, then that’s wrong because brakes are only brake-pad, brake-drum, emergency brake handle, etc. Dorel owns big portion bike industry from Canada and they have not made me an offer and I am trying to keep my intellectual property based american. #185 Slope Generator is worth millions, or billions, to the electric bike industry because anyone who wants to buy an ebike wants to buy a regen ebike.
    If you are blocked from my website, I will explain AC Slope Generator. ACSG is two wiring circuit sets that are activated one at a time, not same time. Rider twists throttle to activate acceleration circuit. Rider releases throttle to activate generator circuit. As soon as rider releases throttle, regen system begins. Tension pulls wires from generator connection to disconnect and then connects to acceleration. Acceleration wiring is battery to inverter to accelerator switch to circuit switch to motor. Generator wiring is motor to circuit switch to battery. The motor in ACSG is an automobile-alternator where acceleration circuit is wired straight to motor, and generator circuit is wired to alternator’s rectifier/regulator to motor.
    I speculate that regenerative capabilities will be so high that I have caused wall charging to become obsolete, as if my ebikes are perpetual ebikes.
    I can co-sign us patent application as original inventor because my invention has been public less than one year. I want $1,000,000 for Slope Generator.
    From, Maxwell Kremer
    Simcrime.com
  13. Copenhagen wheel and BionX have offered re-gen Braking or assitive braking that is verry eficient.
    On a 2000′ elevation climb I can exhaust a full battery over a 15 mile distance and get a full charge down the other side.
    Real world example Mill valley to top of Mount Tam then recharging down to Stinsion Beach. then climb back up to the peak out of stinson beach with no charge at the top and back to full battery at the base in Mill valley.
    Bionx allows you to adjust the amount of regen you want when you dial the power into negative 1-5 on the controll. Copenhagen wheel uses ecelerometers and customization from the smart ophone app along with user input form back pedaling that gives you variable regenerative resistance and assists braking while charging.
    I have also used a third of the battery up to the top of twin peaks in SF and regen a full battery down to the pan handle in GG park.
    Another practical application is a long ride on the bay trail in head wind where I exhausted my battery then a mile of riding while in regen setting 2 (of 5) gets me up the 100 foot elevation hill at Golden Gate Feilds Race track .
    I have a customer that goes to the BOtanic Gardens with her copenhagen wheel and gardens in the albany hills and she swears by her re-gen . She says that riding down hill pedaling at 20 mph in re-regen recharges her copan hagen wheel twice as fast and gives her a full battery for the rest of her day (or the next day ) after tending tho her garden clients. SHe says her Superpedesrian Copenhagen wheel has paid for itself in the first month because she has gotten two new gardening clients that she would have otherwise declined because of distance and elevation. This does not include referrals in these new communities. Thanks to Regenerative braking assistance.
  14. What would be the energy recovery of an bicycle with regenerative braking if it is going through 2 seconds of start and 2 seconds of stop at speeds of 5 kmph or less. This is a typical traffic pattern when in a grid lock pattern. Would it be able to recover 20 percent of energy used in braking in 2 seconds at such slow speeds. One article says that at such low speeds the relative flux change is too small to achieve any recovery. Is this true?
    • These expensive batteries have a maximum of x-amount of charge cycles and need to be charged from mostly drained (20%ish) to full and NOT part charged here & there.
      So if you want to get a bit more range at the cost of having to replace your really expensive battery much more often then by all means go for regenerative brakes if you’ve won the lottery.
      Otherwise buy a higher capacity battery for more range and charge & discharge it properly for value for money and longevity of the system. Ignore the other dreadful advice you’ve read
%d bloggers like this:
