Custom Build Gallery, Roy’s eCortina
April 1, 2014
This months featured build has had three major changes over three years, and each version has been so well done…they could each be featured by themselves in separate articles. But…rather than stretch them into three articles, I found the back-story of the evolution of this bike to be just as interesting as how it ended up.
This impressive builder is Roy (endless-sphere.com username: RWP), who lives in Ventura California. He decided that he wanted to experiment with a Cortina Triton DS hardtail bicycle (Cortina Is based in nearby Santa Barbara, California)…and this reasonably affordable frame is made from CroMoly steel. The round cross-section down-tube, seat-tube, and top-bar allow for an easy construction of custom bracket mounting clamps.
If you like this shape of hardtail frame, and you want it in CroMoly steel, and also with a slack head-tube angle like this…these are sometimes called  a “Dirt Jumper” frame.
_____________________________________________________
xxx
The first version turned out great, but Roy couldn’t help but to want to improve every part to be the best that it could be.
 V1, May 2009
Back in 2009, Roy became fascinated by the E-bikes being built at the endless-sphere forum using the small and light-weight Radio Controlled (RC) model aircraft components. He was already familiar with RC models, and felt that if he could design a compact dual reduction system, he could get significant power from a very small motor that was spinning ultra-high RPMs.
He had seen Bottom-Bracket (BB) drives already, and their benefit was that they gave the motor the use of the bikes gears, so Roy calculated that by also giving the motor some gears to use (compared to a “one-speed” hub motor), he could then select the absolute smallest possible motor.
What makes a BB-drive easily possible is that there is a type of bicycle called a “trials” bike, which has a freewheeling BB, rather than the common method of using a freewheel at the rear wheel. This allows the rear wheels’ solid sprocket to be the smallest possible, and that in-turn allows the BB chainring to also be as small as possible (while still maintaining the desired ratio), and by doing all this, you can obtain the ultimate ground clearance. Because of trials bikes, freewheeling BB components were readily available.
So…when you have two chainrings on a freewheeling BB (which was taken from a trials bike), the motor can drive one chainring, while the other chainring drives the rear wheel. This allows the motor to drive the rear wheel while your pedals are not moving, but…you can still add pedaling when you desire.
xxx
The 2-stage V1 drive is beautiful, but Roy wanted more power.
Because Roy wanted to experiment, he designed a dual reduction that could pivot at the central jackshaft which connects the two reductions. This allowed him to change it’s shape to a “V”, an “L” or in-line so it could be long and thin. He settled on an L-shape, so it would fit snugly inside the frame triangle. Even at this stage, the quality of his work really knocked me out.
After custom fabrication of the aluminum cases that enclose the belt-reductions, Roy had them black-anodised, and the results are nothing short of fantastic. They have an almost military look that provides a very professional finish.
Roy openly confesses that his work back in 2009 was directly inspired by the beautiful drives made by ES member recumpense (Matt Schumacher), and everyone here at electricbike.com has also been a fan of Matts work from the very beginning.
“…Building this bike has been great fun and a personally rewarding experience. I built my first running E-bike with relatively simple tools and some outside machine shop work. It’s an attractive machine that can go faster than I am comfortable riding. It’s a great test bed for future projects, and it’s easy to remove the drive unit from bike to work on it…”
Components:
Towerpro brushless outrunner RC motor, 63mm diameter, 235-Kv
Castle Creations HV-110A Electronic Speed Controller (ESC)
10S-LiPo battery (36V), 10-Ah, later reconfigured for: 5S-LiPo (18V), 20-Ah
Battery enclosed in a water-proof Pelican case on a rear cargo rack.
The throttle is a Magura that is wired into a servo-tester to provide a signal to the RC-ESC
drive belts are 5mm-pitch GT2 X 15mm-wide
Drive unit ratios:
15T/56T primary belt drive, motor to jackshaft
20T / 56T secondary belt drive, jackshaft to drive output shaft
15T / 56T = 3.7:1
20T / 56T = 2.8:1
3.7 * 2.8 = 10.4:1 reduction between the motor and the drive output freewheel
Then, 16T / 48T = 3.0:1 between the drive output and the crankset chainring
10.4 * 3 = 31.4 total reduction between the motor and the BB at the crank
The Towerpro RC motor is rated at 235 rpm/volt
235 * 36 (volts) * 0.85 (efficiency factor) = 7191-RPM’s at top speed
7191 motor-RPM’s / 31.4 reduction ratio = 229 rpm @ the crank
Shimano Nexus 3-speed Internally Geared Hub (IGH), with a disc brake, and a Surly chain tensioner
Tires are Bontrager Hank 2.2 slicks for both the front and back
“…I had to replace the secondary belt with a #25 chain and a tensioner. The belt had started to delaminate. It made this loud low pitched “thumping” noise at slow speeds. I still have a 5mm-pitch 15mm-wide belt for the primary drive…”
“…I took the voltage down from 36V to 18V and now the motor is not getting overheated unless I hold WOT [Wide Open Throttle] for about 5 minutes – then it gets hot. I tend to ride about 15-20mph most of the time while under electric power which is about 2/3 throttle position in top gear. It tops out at about 25-MPH now which is OK with me. I originally wanted to go faster [40-MPH at 36V], but I am quite happy with this performance…”
“…For my next project I will use a larger motor and higher voltage. I probably will not make another through the crank BB-drive system. Don’t get me wrong…it is working very well on the Cortina. I just want more options for keeping the cranks and final drive ratios separate…”
“…My main problem areas have been the slipping secondary belt and going through a lot of worn freewheels, and also the small Towerpro motor is running hot. Not sure what the actual temp is but at times it’s too hot to keep my hand on. It’s hard to access the drive unit internals for easy repair, and the [secondary] belts do not seem to hold up to the torque, except for the primary drive reduction, its fine…”
 V2, April 2011
After the first version was completed, Roy had set a high bar for himself with the quality of the build, but…he wanted to improve the several issues that had been revealed.  I chose the pic of the V2 for this article header because that was the first version I saw, and it is also the version that has been published in several magazines. A central battery, combined with a low and central mid-drive that gives the motor the use of at least 3 gears is a configuration that is really proving itself to be popular these days…and Roy was doing this starting in 2009!
xxx
The steel Cortina frame has allowed Roy to easily weld custom mounts anywhere he needs.
The most immediate visual change that I noticed in the second version is that…Roy moved the battery from a case on the rear cargo rack to an absolutely awesome triangle enclosure. Three metal tabs were welded into the corners of the frame triangle, and small plates connected these tabs to an aluminum sheet that forms a central backbone, and it also divides the pack, with half on each side.
xxx
The aluminum web that Roy installed in the central frame triangle space has provided a solid foundation to mount the batteries and wiring harness. Here you can see the very strong aluminum drive mount has not been anodized yet.
After the first glance, the second thing that jumps out is the completely new drive unit. Roy consulted with Matt Schumacher and moved up to a larger Astro 3220 inrunner, using a single reduction with a chain instead of a belt. Using a chain as a high-RPM primary reduction might be slightly louder than a belt, but it does allow for a greater reduction in one step because of a small drive-sprocket. In spite of any additional noise that may be caused, a primary chain will not slip, which might be an issue with a high-powered belt-drive.
Also, this drives output shaft is connected directly to the rear wheels’ sprocket cluster. A more common method would be to reduce the drives RPMs down to the BB pedal-speed, and then immediately gear the bicycle’s main drive chain back up from the BB to the rear wheel…which is normally about a 1:4/3:1 ratio. Between the drive bypassing the BB and also the very large motor reduction, Roy could achieve his goals with a single reduction.
xxx
The aluminum tube-clamp and drive mount are aluminum, and after Roy fabricated them himself he had them anodized black to continue the professional looking theme that has made this build so outstanding.
xxx
Here’s a close-up of the primary chain reduction and the slip-clutch. The perfectly round tubing on the down-tube simplified the creation of the beefy clamps. Matts Astro drive-mounts are a thing of beauty.
xxx
The recumpense drive was a perfect addition to Roys V2 Cortina. Notice that the central clamps can be adjusted so the motor can be rotated to any convenient angle.
xxx
The Castle Creations controller is very small, and you can almost see it under the wires near the head-tube. The first battery pack is a small and light 12S / 44V system made from four 6S / 5000-mAh bricks (two on each side), for 10-Ah’s, but…you can see there is still room for more…
xxx
If you like machines as much as I do, this shot of the Cortina is a thing of beauty. The motor and the pedals both have independent use of the 3 gears in the Shimano Nexus IGH.
Motor: Astro 3220 (5 turn)
Primary Drive Assembly: Matt Schumaker
Tube Clamps: Self made
Torque Limiting slip-clutch: Dalton OSD-225
Motor Drive Freewheel: Try-All 108.9 16T
Controller: moved up from the HV110A to the HV160A + 2 additional Capacitors
Battery: LiPo – 44V 10-Ah, 12S / 2P, 25C, 6S/5000-mAh in each brick
Electronics: Matt put the servo tester and BEC into a small electronics project box
PreCharge anti-spark resistor: 10 watt, 1-ohm
Throttle: Magura
Rear Hub: Shimano Nexus 3-Speed
Sprockets at rear hub: Combination of Gary Goodrums adapter [http://www.tppacks.com/proddetail.asp?prod=EBKE-zz-FWAdapter], Big Cheese adapter modded to fit the 16T Nexus sprocket, a 50T chainring and Shimano 18T Freewheel
Chains: Pedal and motor powered drive chains are both Wipperman 108, primary drive chain is #25
Bottom Bracket Cartridge: Sick Bike Parts, 153 mm wide
[http://www.sickbikeparts.com/catalog/product_info.php?cPath=23&products_id=107&osCsid=m0jn9rpbi82vedbkev964e85e4]
Bike Frame: Cortina Triton DS CroMo [http://en.wikipedia.org/wiki/Cortina_Cycles]
Forks: Marzocchi Bomber
Rims & Tires: 26-inch CST Cyclops 26 X 2.4
Weight: 59 pounds
Primary chain reduction: 12T/45T  3.7:1
Secondary chain reduction: 16T/50T  3.1:1
Overall reduction: 11.7:1
“…Goes like a bat out of hell geared for 45-mph. So far I have only had it up to 35-MPH and it feels very stable. Issue: The triangle is too small, I wanted to get 8 packs in it, but…I only have four now with the possibility to add another two. The torque-limiter seems to grab and not slip smoothly – feels a bit like a slipping timing belt. Still working out how much pressure to apply, after every ride I adjust it some. This thing gets hot, I measured over 160 degrees F after a short ride. I think this means its slipping a lot…not good”
“….I took off the torque-limiter because it was causing trouble, but then…the Nexus 3-speed croaked. First gear is inoperable while I still have 2nd & 3rd…The 3220 is running at about 170F (77C)…I am going to rewind a [larger]  80 X 85 and try it out.
A very interesting bit of news is that the V2 cortina was raced at Willow Springs Karting race course in California in 2011.
V3, May 2012
The single reduction chain on the previous V2 managed to eliminate any slipping, but chains are noisier than belts. For this version, Roy went back to a quiet belt-drive, but since the previous 15mm wide size that he used earlier on the V1 would slip too much (damaging the belt), he moved up to a 25mm wide Gates Powergrip GT belt.
However…even with the wider belt, Roy needed to add an idler that would not only take up any slack, it would also “back bend” the belt to increase the number of drive-pulley teeth that the belt engaged (to eliminate all slippage).
Primary stage is 95T / 20T, or 4.7:1
The stock Turnigy 8085 motor I am currently using is 170kv (80mm diameter, 85mm long)
“…It’s geared to top out in each of the three gears at 25mph / 31mph / 39mph – so attempting to add pedaling is a joke. The top pedal-gear is the only useful gear for pedaling, since the bike accelerates so quickly…”
After more research, Roy moved up from the Castle Creations HV-110 to a HV160 on the V3.
Batteries: six 25C 6S Turnigy batteries, 44V / 15-Ah.
13T ACS-Crossfire freewheel on Matt’s shaft adapter.
Stand alone high amp Cycle Analyst.
Because both chains are vary strong BMX, I modified the derailleur to allow for the wider chain and I used only three sprockets on the cassette, with two spacers between each sprocket to accommodate the wider chain. Shifting is 2-clicks of the trigger shifters for each gear.
Roy switched to smaller 24-inch wheels so he could swap up to fatter tires, and he now is using Hookworms. The lower 170-Kv of this motor means that Roy can use 44V, but still avoids needing a second reduction. The RPMs of the drive were low enough that he could go back to using a “trials” freewheeling BB, which simplified the adjustment of his chainline (this is the number of millimeters between the centerline of the bike, and the center of the drive-chain to the rear wheel).
xxx
To get enough reduction in a single stage, he had to use a fairly small drive pulley, so Roy used a roller that back-bends the belt to engage as many teeth as possible.
xxx
Matt Schumacher uses half-inch diameter case-hardened shafts, and here you can see the shaft-adapter that mounts a 13T freewheel from ACS-Crossfire. This freewheel isolates the motor drive when you are only pedaling, and the flanged White-Industries ENO freewheel in the center of the crankset sprocket allows the rider the option of resting his feet when the motor is driving the bike.
xxx
Here’s the drive unit from another angle, and here you can even see the tread on the well-regarded Hookworm tire on the rear, which corners well on fast street cornering.
In the pic below, you can see the bright red “kill switch” that he has mounted within easy reach, and every E-bike should have one of those. Notice that Roy has changed the rear wheel to external sprockets with a common derailleur, since these can take more power than the available Internally-Geared-Hubs (IGH’s), and…this version of his Cortina definitely puts out plenty of power.
xxx
Roy is certain that this is the final version of the Cortina, but…he has recently started a completely new project. I am looking forward to writing about that project as soon as he is done with it, and I am sure I will enjoy it as much as I have enjoyed this one.
The endless-sphere discussion about the V1.
Here is the V2 chat.
Aaaand also the V3.
Wired magazine wrote about the V2 in 2011.
Also, coolest-gadgets.com wrote about the V2 Cortina
Here is Roys personal website, and this link is his page that has a copy of an article on the V3 from Current EVents magazine.
Written by Ron/Spinningmagnets, April 2014
1 Comments
  1. I am not very familiar with the parts of a bicycle, but I know everything on this ride is awesome! I hope I can customize my Conspiracy Standard Build Morpheus bike soon. This is an inspiration.
%d bloggers like this:
